I hope you don't think I was talking about you... I wasn't
The whole trick with the network map is that it's unpredictable. Only the system maintainers know when one is going to be transmitted. I'm sure it can be done on a weekly/monthly type of schedule, but I bet it probably only happens after some significant changes have been made and the maintainer wants to ensure that all of the radios get updated -- and they probably then force a network map broadcast.
DSDPlus FL and a dongle is all you need. If a network map is being broadcast on a site that you are monitoring, an alert will come up on the screen indicating so. It will say which LCN it is being broadcast on. That LCN might be the second timeslot of the current CC, or it might be on a timeslot on one of the normal voice CCs. When I was monitoring the other day, two or three of the 25-29 sites (you know, rochester mills, blairsville, etc) were sending it right on the second timeslot of the CC. But if you are monitoring it and the CC says its broadcasting on some other LCN, you'll then have to switch DSDPlus to that frequency/LCN in order to pick up the map. They are generally broadcast for many hours. And they are repeatedly broadcast. There is no confirmation from any radios during the process that they have received it (I think it's using UDP protocol), so it gets broadcast for many hours or perhaps even a day across [usually] all sites so that as many radios as possible have a chance to pick up the changes.
Having the ability to use DSDPLus though is a requirement of it.
Mike
