Midland 70-380b programming
RadioChief55
Is there anyone who still can/will reprogram an old VHF Midland 70-380b radio? Or better yet, what do I need to program it myself? I know it doesn't do narrow band, but it is great for using to just monitor. I'd like to change some settings and change some frequencies. I looked for a Midland thread in the forum and did a search with no luck.
Thanks for any info.
John
NC4AB
Wallburg, NC
John -
Sent you a PM, the Midland you have can be programmed using a Midland 70-1000 series eprom programmer after you have erased the eprom in the Z-273 memory module with a UV eprom eraser.
For the ones who are not faint of heart you can unsolder the eprom from the Z-273, erase it and program it directly using most any aftermarket eprom programmer then put it back in the memory module. There is a lot of useful info also available on the Midland Yahoo group.
RadioChief55
Ok, I'm resurrecting this old post I put up a while ago. I'm looking once again to see if anyone can program this old radio? I want to program it to use to receive marine radio. I'm in NJ. Thanks
