With your help I looked at the above antennas but ialso noticed this one in the link brlow. I haven't purchased it yet as i wondered if you could give me your opinion on it. Again thank you.
ABBREE 27Mhz BNC Retractable/Telescopic 9.17/51-Inch Antenna for Handheld CB Radio Full Kit with PL-259 Connector Mobile/Car Radio Antenna for Midland Cobra Uniden Maxon President Car CB Radio : Amazon.ca: Electronics
www.amazon.ca
How are you intending to use it? I’ll assume
mobile for the comments below.
— That telescoping antenna is going to fail it hits anything.
So, for a portable radio in use as a mobile (vehicle), an adaptor BNC-UHF of the right spec will allow the use of any typical CB coax plus antenna as
arudlang noted in Post #3
I’d sure take that route over the linked item.
A WILSON
500 would be a minimum as a packaged magnetic antenna system I’d consider (I’d rather spend more and have the
5000).
You have in hand
the less important of a CB Radio system:
1). The coax/antenna system is chief.
2). The power system is second.
3). What gear you plug into these two is third.
Now, if it’s not a mobile system you have in mind, the longer flex antennas for walking around look good to me.
If you’re thinking about use while camping, say, then a dipole (and other choices) where you can get it up in the air would
still be a better choice than the linked antenna.
I don’t see the linked item as being “good” for anything given what’s available (or that you can DIY).
— It’s a good question to have asked and gotten out of the way. It has a
magnet and it has
attached coax,
but the antenna whip is an inferior part (lacks robustness & performance via height).
