midland landmobile commercial radio
#1
A friend of mine just currently got a job with the local animal shelter as the dog warden and the 911 center wants you to talk to them on 39.90 mhz. He has a midland landmobile model 70-0375B commercial radio that will work but when attempting to transmit, it will for about a second and then stops and throws error code E3. I have a slight radio background but i have no idea about what the error codes mean or what to do to fix it. can some one please help??
SteveC0625
Northville, NY (Fulton County)
#4
ok. thanks. what do we need to do to fix it?
Honest answer: It will cost more to have it repaired (if a shop will even work on it) that it will to buy a good used programmable two way. There are lots of them for sale these days including high quality portables from Motorola and others.
It it was me, I'd hunt for a bargain on a Motorola CDM or GM300 series. But then I have the software and cables to program them plus lots of items like the right brackets, cables, and mics necessary for a full install.
parma,ohio
#5
lowband radio
I just had a friend sell a LOWBAND 35-50 MHZ cdm750 on ebay for me not sure if the guy paid for it or if he changed his mind on it will ask if its been sold.
Big D, little a, double l, a s
#6
VCO out of lock is not a fatal error! That model should operate fine at 39.9mhz as its range is stated as 36-42mhz. Personally I would find a Midland radio shop, talk to them, and determine what needs to be done. It should be fine, but sounds as if it needs just a bit of tweaking. It may have been used previously at say 42 and tweaked there and just needs to be moved.
But it is not dead!!!
In the 'patch
#8
Wirelessly posted (Mozilla/5.0 (iPad; CPU OS 6_0_1 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A523 Safari/8536.25)
A simple tuning of the VCO should fix the problem. Not a biggie at all and defiantly no need to replace the radio if it is just the VCO.
In the 'patch
#9
How do you figure? To re-tune the VCO should not take more than half an hour from the first case screw removal to the last screw being put back in the case. You are going to pay a couple of hundred bucks for a used CDM.
In my experience, Midland radios are very easy to work on and are solid performers.
SteveC0625
#10
I may be off base here, but the error code alone doesn't guarantee that it only needs a simple VCO tuning. If the radio is older than 10 to 15 years, the OP may not be able to find a shop in his area to even work on it. And given current shop rates, he may spend a lot more than everyone thinks it would cost.
I'm seeing CDM750's selling for around $100-$125 and GM300 series for a bit less.
