Midland STM-1050B mobile programming
jim202
New Orleans region
I have a Midland STM-1050B mobile that I would like to program again. I believe that I do have the software, but have lost the programming cable after moving 3 times.
Does anyone have any information on the correct programming cable and can one be made from scratch? Just need a diagram of the circuit and I can handle it from there.
The other question I have is can the accessory connector be used to make the programming connection or is the mic connector the only place it can be programmed from?
Avery93
AL
Factory programming cable part number is ACC-2600. It is 9-pin serial, and has both a RJ-45 and Hirose type connector that will program both mobiles and portables. Programming Software is MRP25. As far as I'm aware, the mobiles will only program through the RJ-45 mic jack.
I've grown to almost despise these radios after having to deal with a neighboring county that bought a whole fleet of them when they first came out... Numerous firmware problems relating to P25 and scan, awkward user interface, and a high failure rate. Not to mention everything about them, particularly the programming software, is far more complicated than it needs to be.
