what is the wire color code for realistic cb microphones
W whirley1 Member Joined Feb 12, 2013 Messages 43 Location wichita, ks May 6, 2013 #1 what is the wire color code for realistic cb microphones
R r_eugene1 Member Joined Jun 20, 2011 Messages 143 Location Southwest Ohio May 6, 2013 #2 Hope this link will help you depending on what mic you are trying to wire up to your radio. If not someone else may be able to. Microphone Wiring Diagrams - www.WalcottCB.com
W W2PMX Member Joined Oct 29, 2011 Messages 333 Location Fayetteville NC May 7, 2013 #3 Rule of thumb: The shield is ground. The wire inside the shield is the hot mic lead. The other two are PTT. (If there's only 1 additional wire it's PTT and they're using the shield for ground which is cheap, bad practice and very common.)
