Mini-max xeron 550w amp
darticus
Sparta, New Jersey
Thinking of selling this. Anyone ever use one? This has been on my shelf for years and time to part. Thanks Ron
K7MEM
Swartz Creek, Michigan
You don't give any info about it. Is that a CB amp? What is the sweep tube type?
Yes, it is a amplifier intended for use on the Citizen Band. It uses four 12GB3 TUBES. The dead give away is the AM/SSB switch. The switch doesn't actually change the tube bias. It just increases the carrier sense transmit delay, in the SSB position.
There was a messy posting about the same amp a few years ago.
http://forums.radioreference.com/cb-radio-forum/252019-4-tube-amp-identification.html
As is, it's not legal to use on any band, no matter what license you have. However, if you have a ham license, you could just consider the amp as parts and add/remove the necessary circuitry to make it legal/usable on 10 Meters.
Martin - K7MEM
Slow and steady
If this has been off the air for quite the few years, your filter caps may be dried out. Just plugging it in may blow out the caps. You may want to consider replacing any of the caps.
Do you have access to a variac or other variable voltage transformer that you can use to slowly raise the line voltage?
