prcguy - you got me thinking about another application for the LVP loop:
Use it as the "sense" or auxiliary antenna for phasing noise cancellers like the MFJ 1025/1026 or Timewave units.
Sometimes even with these phase cancellers, one can't obtain a phase cancellation if their "sense" antenna is large physically, or electrically random due to common-mode current on the sense antenna feedline.
The nature of a small vertical loop - if properly constructed usually means less common mode interaction. Thus you have a small "point source" in reverse for this application with a phase canceller, and may now obtain a cancellation where you couldn't before.
Rotating the loop to accentuate / null offending signals, from this "point source in reverse" may help one obtain a phase cancel.
I haven't tried this, but just thinking out loud for those who may have tried one of the phase cancellers and not been successful when there is qrm coming in from all directions. Using the LVP loop as the auxiliary sense antenna might be very interesting.
