dont go to radio shack please... overpriced and junky crap is what they sell
i recommend paladin tools series 1300 style or something like that
something that is along those specs - so its 50-70 bucks? you only have to buy it once
Paladin Tools
dies are not that expensive
and to FINALLY answer your question
mini uhf for rg-8x you use .255 and .060
for rg-58 etc you use .213 and .068
easy way to do these (like bnc..tnc.sma etc ) is to slip ferrule over coax - cut back center cable just enough to crimp on center pin - make sure it holds - then strip the rest back using the connector as a guide - you usually want the insulation stripped back to where the knurled part of the connector changes to smooth (usually) and then slip ferrule up over shield and it creases the shield - trim the shield with scissors and then crimp ferrule - works great no measuring
as a general rule (if you dont know the actual size to use) - go bigger on the crimp hole
you can always go smaller and try another crimp - if its too big it wont affect it -
BUT if you go too small - you will break the pin(s) or crush the coax
special note - if you are going to crimp 9913 connectors - you need the die for it 9913 uses a .128 for center pin - as far as i know - a die like a rfa4005-02 or equiv has .100 .128 and .429 on it
