Minitor 6 Engineer's Logon
WuLabsWuTecH
Does anyone know if the minitor 6 has an engineer's logon where you can change a 1 frequency to a 5? Kind of like how you could change 1 channel Minitor 4's and 5's to 2 channel ones?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
I do believe that someone already took a trip through the PPS with a hex editor and determined that there is no engineering mode hidden in the software. They posted about it either here on RR or over on batlabs. If you do a bit searching, you may find the thread on this.
Anyway, bottom line is: NO ENGINEERING MODE.
N8CAM
Don't mean to bring up a dead forum.... But did anyone find a solution??
APX7500X2
NY/CT
The Minitor 3-4-5 were made by Unication and had the back door in, The Minitor 6 is made by Motorola so no more back door.
That's why Unication now makes the G1-G4-G5 series that are far superior (but bigger) to the Minitor 6
krokus
Southeastern Michigan
I thought Unication made the 6, too.
Sent via Tapatalk
