Minitor III charging question
Asmitty0010
New Hampshire
#1
Sometimes when I put my minitor III in the charger the yellow "Pager" light on the charger flickers on and off. I have to wiggle the pager around to make it light up and sometimes when it does light it's very dim.
Is the pager still charging even if the light is off? Is there a problem with the charger itself or the metal contacts on the bottom of the pager dirty or something?
Thanks for any help.
