Minitor Pager Station Alerting
fire2173
My department is searching for an already built station alerting system that will plug into a minitor amplified charger. We are looking to connect it a bell or 2 that will activate when we have a call. Is there any over the counter ones that we can purchase? Thanks.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you reach out to a company that installs residential and commercial intrusion alarms, they should have any number of warning systems that can be triggered by a low amperage switching system such as the charger amps for the Minitor Pagers.
The home brew system recommended by sfd119 is also a good choice. The components needed are readily available and can be assembled by any competent electronics tech. It's easily modified for larger stations and other applications.
