Minitor V 2-tones
lrcrabtree
Paige, TX
Local radio shop says that one of the tone sets that I need is: 726.8 / 688.3; however the minitor changes those entries to 726.9 / 688.7, no matter how I enter them. [Coding Option: R168(None); F1: 151.1750; 2 channel with voice store]
Any ideas how to get it to program the tone pair that the local radio shop thinks is correct?
Larry
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Larry
Discussed several times before. The pager can handle about half a percent variation with no problems. The synthesizer logic causes the change. It is not an issue.
jeatock
090-45-50 W, 39-43-22 N
+ Ditto.
You are entering an audio frequency in Hz, not an exact code. Since very little in the radio world is really that precise a small error is still within decode specs.
... or should be. Older Minitors were more forgiving. Remember that tone decode started out by vibrating a mechanical reed with a magnet on the end that would induce a voltage in a coil when it resonated. Talk about in-precise!
