Minitor V programming glitch 1251.4 Hz
clifford1
Reading, PA
Any help with this issue is appreciated!
Using the Minitor V PPS software and cradle, I went into several fire pagers to add the following tone pair:
Tone 1: 879.0
Tone 2: 832.5
I read each pager, added the new tones, then wrote the codeplug back to the pager each time.
A test of the new tones resulted in a correct activation of the pagers.
However, after the programming, several of the users complained that they were getting activations for other agencies. The fire police tones were not working, however the pagers were now activating for the local ambulance squad.
Upon review of the programming, I discovered the following:
A tone pair for the fire police that was previously in the pager was "changed" when the codeplug was read and written back:
Tone 1: 569.1
Tone 2: 1251.4
Tone 2 (1251.4) "changed" to 1285.8 without my doing! In fact, when I attempted to change it back to the correct tone, the software changes the tone back each time I hit enter Even more troubling, the tone that I need is the only one that appears to have been omitted from the full tone list!!!!
So, the software "changed" the tones from fire police to ambulance, and won't let me change them back!!!
Tone 1251.5 Hz appears to have been "eliminated" from the list of tones!
The worst part is, I was doing this for a neighboring fire company as a favor to save them some $$$. Now their fire police aren't getting alerted for calls (and it happened during the hurricane!!!) Can't get any worse!!!!
It is a motorola tone system.
Help!!
Chris C.
gary123
Im not 100% on the programming but I have seen similar issues on other pagers. what i suspect is happening is that the cps is selceting the closest 'legit' code to the tone you are entering. see if there is a list of the valid cap codes for that unit, also check the capcode group you may have the wrong group selected.
if this dosnt help ask back and i will see what i can find out for you.
SteveC0625
Northville, NY (Fulton County)
1251.4 is a legit tone from Motorola Reed Group 6.
I would suggest clearing all tones, write the pager, remove it from the cradle, turn it off for at least 30 seconds, and then turn it on again in programming mode, put it back in the cradle, and try to write the proper tones to it. That may take care of the problem.
Just a question, on the General tab, is the tone system set to Motorola?
On the Channel F1 tab, what coding option is selected? And how many different tone codes are you trying to assign to the frequency?
clifford1
Reading, PA
Thanks for the replies guys.
The system is set to "Motorola". The code "used to be" listed under group 6, but now appears to have been deleted. If I could post a screenshot you would see that 1251.4 is missing from the code charts (there is a blank spot where it "should" be). The software automatically changes it to the next code in line (which unfortunately is Tone 2 for the ambulance tone pair, not the fire police!!!)
I am trying to re-download and install the software again seeing if that helps.
Coding option is R168 (None). I did note there was a difference in the codeplug version from the pagers I had programmed previously to these ones. My version was 0.044, I think the problem pagers had 0.047 - not sure what this means of if it matters.
clifford1
Reading, PA
FYI - I downloaded the latest software from the Motorola website, and it appears to have fixed the issue!!! I guess you have to stay on top of this or your software will just stop working on you (at a fire department, during a hurricane).
Lesson learned. Hopefully this thread may help someone else with the same issue.
Thanks!!
Chris C.
