Minitor VI not receiving?
Tunkhannock, PA
#1
Hello all
I have a Minitor VI that I'm working on, and need some help. The Minitor VI won't receive anything. It used to, and stopped suddenly. There was something rattling inside, so I took apart the pager and came to find a metal cover came un-soldered and was just clinking around the pager. So I re-soldered it back to the board, but the pager still isn't receiving anything. I looked at the board when I had it apart, and nothing looked broken.
Does anyone have a schematic for the board so I can check and see if maybe the antenna on the board is messed up, or the RF board is. I'm not sure if this pager even uses an Antenna.. I haven't used a Minitor Pager since I got my G1.
Thanks in advance!
n3obl
PA
#2
Motorola did not release a manual with schematics as these were intended only for depot service.
