Minnesota United FC/Allianz Field
#1
So, now that Allianz Field is open, does anybody happen to know what frequencies will be in use there?
#3
Thank you for the reply. It looks like it is authorized for DMR modulation and is a trunked license. I suspect that means it is a Motorola Capacity Plus system then.
