I am currently having some issues on my SDS100 where I am missing the first few seconds of transmissions on conventional P25 channels or sometimes missing the very short reply on them. I am using the Remtronix BNC 800 antenna and the channel I was listening to was an 800 conventional. Could it be a filter issue? Should I try turning the filter off completely? I also turned off the squelch completely and I still missed a few seconds of the transmission. Does anybody have any ideas about this?
I haven't read any of the other replies, so sorry if this has already been stated. On any type of radio system that uses repeaters, there is a delay between keyup of the mic after the talker depresses the PTT switch and when the repeater engages and is capable of repeating the voice signals. We always teach new hams to press the PTT switch then wait two seconds before talking. However, most people don't do that and the result is that the first 1 or 2 seconds of their TX is clipped off. I hear this all the time with hams and with PD and other radio services. There could be other issues at play, but the most common cause of clipping of the first second or two of a TX is simply due to human error--talking before the repeater has been activated to repeat the TX. If this is the cause of the clipping, then unfortunately there is nothing you can do to solve the issue on your end.
