Missing plane at Burke Lakefront after takeoff
Lake County, OH
#1
Just saw on Fox 8 about a missing plane after takeoff at Burke. I'm at work which we monitor Unicom and have not heard a single broadcast, and I cannot pull the scanner out. I did see a USCG chopper was on scene from the news broadcast. Anybody know what channels they are operating on or any updates?
Indianapolis
#2
Six souls reported, the FlightAware track does not look good at all. I'm thinking flame out or fuel but a gust lock at night has happened before...
Mike-KC8OWL
Henderson, NV
#5
USCG Rescue 6566 is flying a search pattern. Just confirmed the aircraft also had a 406 beacon onboard. Comms on freq that eorange identified above.
northernsummit
Macedonia, Ohio
#6
Rescue 2004 out of Elizabeth City (C-130) took over about an hour ago and the Canadian C-130 went back. Current plan is to continue until nightfall and re-evaluate. Anyone hearing anything outside of 157.05?
#8
I saw the news where the coast guard had mentioned receiving sporadic weak ELT signals. I wonder if anyone has tried using a sensitive receiver with CW or SSB detector to locate the plane. Using a product detector receiver is way more sensitive than an AM receiver.
