fmulder13
Hey all,
I'm revamping my mobile setup, and am looking for some co-phasing advice. Since I'm interested in monitoring almost only the VHF band, I'm going to run a Motorola Spectrum 5/8 on a mag mount to my Pro-2096. I'm considering buying a second Spectrum, and running it on another mag mount to my scanner with a RadioShack BNC T-adapter. As far as I've been able to determine about co phasing, I need identical antennas (check), identical lengths of coax (check,) and the placement must be correct (check. I want to place them both on the trunk, and will probably put them right on the edges on opposite sides of the trunk.)
Assuming I'm correct on my co-phasing technique, my question is thus. I've read that co-phasing two antennas will create a more directional pattern that is parallel to the car. I've also read that on a mobile setup, since the ground plane of a vehicle (the metal body) is so uneven co-phasing will actually create a more omnidirectional pattern. Any thoughts on whether this is true?
Most of the signals I'm trying to receive are fairly strong, but I want to see if I can't pick up my local PD when they're not using the repeater on their portables. Would co-phasing help with this or am I just out of luck and shouldn't waste my money on a second Spectrum?
