Mobile milcom/milsat antenna
N8IAA
Fortunately, GA
Just wondering what ya'll are using for a mobile milcom/milsat antenna. I have a Larsen 1/4~ that is uncut with the lowest frequency of 136MHz. Works ok, but would like better. Any suggestions? Has anyone tried the Super M?
Wondering,
Larry
Alliance01TX
DFW Texas
Mil-Com /Mil-Satcom
Howdy
The questions around Mil-Com and Mil-Satcom are likely more complex in the answers as the Mil-Air is used both VHF and UHF (vast majority). The Mil-Satcom is a couple of different areas, as in the UHF-AM Mode from an Air-to-Air/Ground and then we have the 'real' Mil-Satcom that requires a RHC (right hand circular) antenna to the Mil-Satcom birds.
So, a Discone of wideband will give you the best 'utility' coverage, but if you want better coverage you would need a couple of antenn's, especially the RHC if you want better reception of the Mil-Satcom frequencies in my opinion.
Others will likely chime in with better views of what works in various config's....I use an AT-197GR for pure Mil Aircraft in the 224~400 Mhz range with the center around ~311.000 (old SAC Primary) and itworks well. I use a Diamond Discone for Wide-Band and a special made RHC Antenna for SATCOM-On-The-Move (SOTM) use.
Hope the helps.
Thx
Bill
N8IAA
Fortunately, GA
Howdy
Hope the helps.
Thx
Bill
For mobile:confused: My question is "what are people using for mobile use"?
Larry
N9JCQ
Lake Barrington, IL
I use the Niljon Super M Mobile coupled to either my 396T, Pro-43 or my Yupi 7100. I think it does damn good for MILAIR. I live in the Chicago area and I can monitor Air to air in Red Hills, near Volk Field and sometimes over Lake Michigan pretty well. These areas are a considerable distance from me.
I do not Monitor MIlsats. I hope this helps
N8IAA
Fortunately, GA
That was what I thought, too. The design lends itself to those frequencies. I have a better chance of having that on the car instead of the turnstile:D
Larry
Alliance01TX
DFW Texas
Howdy
Have a look around relative to the home-brew SATCOM Antenna as discussed in a 2-part Monitoring Times write up a little over a year ago. It was not a mobile version, but for under $50. you can have a nice SATCOM Antenna. The key is the 'phasing' (Right Hand Circular or RHC) that really makes a difference and vastly improved reception....Suspect someone has made a mobile version perhaps?
prcguy
If you bolt the MT X-wing to your trunk lid it will become a mobile UHF satcom antenna. You could also bolt the bottom pipe cap to a large 3/8-24 mag mount and make it mobile. You would have to shorten the support tube slightly in this case due to the added height of the mag mount.
I drive around occasionally with the commercially made mag mount a few posts up and it gets some strange looks.
prcguy
Howdy
krokus
Southeastern Michigan
prcguy
Of the three antennas you listed only one is a satcom and the others are vertically polarized LOS antennas.
I had a Navy SSR-1 antenna and was not impressed, the MT-X-wing project antenna works much better in my opinion.
I also scaled down and built an Eggbeater II antenna for 260MHz and the X-wing worked better. The Eggbeater was complicated to build and needed some odd 93ohm coax for the phasing harness.
prcguy
Here is an antenna I used in the military, for UHF comms:
http://www.wade-antenna.com/TACO/Coax-Stub.pdf
For receive only, the US Navy does/did use these on ship:
Fleet Broadband Subsystem Equipment
If you really want something really stout:
http://www.rfcomm.harris.com/media/RF-3184-AT320_tcm26-9099.pdf
I would consider some type of turnstile antenna, also called an "egg beater." The SSR-1 antenna would be a decent platform to start with, and pare down the ruggedness a bit.
