Hi everyone,
I recently bought a quad band TYT TH-9800 mobile transceiver, 10m/6m/2m/70cm. It came as a package with a trunk mount quad antenna. I want to use it as a base station transceiver, but I'm not going to be living here long enough to make it worth putting up permanent antennas.
I know you can convert mobile antennas to a base station using radials, though it's not an optimum solution. Is it possible to do that with a quad band antenna? If it is, I have no idea how long to make radials for 4 bands.
The antenna is going to be mounted in the attic. I'm not too concerned with perfect reception/transmission, I just want to be able to play around & learn how to use the radio.
I was wondering if anyone here could give me some guidance. I'd appreciate It!
Chris Carson
Chris Carson
