Mobiletech Communications ??
Saint
Fort Erie Ontario Canada
This is the system,
http://www.radioreference.com/apps/db/?sid=6862
I have my 396t scanner in CC Only mode and it is stopping on 153.335 and I'm getting a full 5 bars strength on this frequency.
Also 153.605 is coming in .
I do not hear any audio on the frequencies but talk groups keep flashing one after another on both frequencies. Why no audio and only flashing talk groups. ??? any help appreciated.
Steve
Saint
Looks like you may've found a site in Tonawanda that is not yet documented.
WPRI746 (PFEIFFER, TERRY) FCC Callsign Details
WPVS573 (Terry L. Pfeiffer) FCC Callsign Details
What talkgroups are you seeing? It could be data that the scanner is muting, may not be voice.
on 153.335 mhz
0-01-133
0-11-038
0-07-110
0-09-069
0-11-112
0-11-038
0-24-000
0-11-133
0-04-001
and there are more talkgroups, they just pop up one after another
on 153.605 mhz
0-05-071
0-05-133
0-01-128
0-02-065
0-05-121
0-01-090
and so on
But no audio
Steve
DSheirer
Fulton, NY
on 153.335 mhz
0-01-133
0-11-038
0-07-110
0-09-069
0-11-112
0-11-038
0-24-000
0-11-133
0-04-001
on 153.605 mhz
0-05-071
0-05-133
0-01-128
0-02-065
0-05-121
0-01-090
and so on
But no audio
Steve
Steve, if it's an LTR-Net site ... each LTR-Net site has a Home Status Channel that is transmitting 24/7 with signalling. Any active calls on any of the LCNs will also show their talkgroup on the home channel. Half of the messaging is LTR messages and the other half is LTR-Net. The LTR-Net messages will show the opposite zone, so if your normal LTR talkgroups are 0-xx-xxx, then the LTR-Net messages will be 1-xx-xxx, or vice-versa.
The 0-24-000 talkgroup that your scanner showed, looks like the LTR-Net LCN transmit frequency message. Other LTR-Net messages that you may see:
x-17-xxx - unique radio id address
x-18-xxx - home site id
x-24-xxx - LCN transmit frequency
x-25-xxx - LCN receive frequency
x-26-xxx - neighbor site id
x-28-xxx - site LCN channel map
Your scanner may be mis-interpreting the LTR-Net messages. Your best bet is to run slicerwizard's LTR-Analyzer version 3 against it ... that will show you all of the LTR-Net messages, correctly translated.
Do you have an SDR dongle or something that you can feed LTR-Analyzer with?
I'm going to be out that way the first week in January ... and can confirm it for you, if you can't run LTRA against it right now.
Denny
Saint
Denny
Does anyone have the link to download LTR-Analyzer version 3
Steve
I can download Unitrunker if that's better ???
Steve
DSheirer
Fulton, NY
LTRA version 3 is not posted for download ... Unitrunker doesn't do LTR-Net (as far as I know).
Can you PM your email address to me ... I'll email you a copy.
Saint
Ltr a-log
Denny
Just in case anyone else is interested in what LTR-A picked up this is the log,
this is from 153.335 mhz
Steve
- OSW: 1 01 01 255 09 07 BUSY FREE=9 LCN=1
- OSW: 0 25 07 128 01 17 RX FREQ LCN=7 BAND=0 TIER=0 OFFSET HI=1 OFFSET=7
632
- OSW: 0 24 09 038 24 4C TX FREQ LCN=9 OFFSET LO=1240
- OSW: 1 01 01 255 07 14 BUSY FREE=7 LCN=1
- OSW: 0 24 09 133 16 6F TX FREQ LCN=9 BAND=1 TIER=3 OFFSET HI=0 OFFSET=1
240
240
- OSW: 0 25 09 069 28 43 RX FREQ LCN=9 OFFSET LO=2236
- OSW: 1 01 01 255 11 00 BUSY FREE=11 LCN=1
- OSW: 0 25 09 128 04 6B RX FREQ LCN=9 BAND=0 TIER=0 OFFSET HI=4 OFFSET=1
8620
8620
- OSW: 0 24 11 038 12 4D TX FREQ LCN=11 OFFSET LO=1228
- OSW: 0 24 11 133 16 52 TX FREQ LCN=11 BAND=1 TIER=3 OFFSET HI=0 OFFSET=
1228
1228
- OSW: 0 25 11 112 00 49 RX FREQ LCN=11 OFFSET LO=3584
- OSW: 0 25 11 128 01 18 RX FREQ LCN=11 BAND=0 TIER=0 OFFSET HI=1 OFFSET=
7680
7680
- OSW: 0 28 01 065 00 0F ACTIVE LCNS LO: 1 7 9
- OSW: 0 28 04 001 00 4C ACTIVE LCNS HI: 11
- OSW: 0 26 00 097 30 05 NEIGHBOR=62 SEQ=0 RANK=3
- OSW: 0 26 02 032 28 7B NEIGHBOR=28 SEQ=1 RANK=1
- OSW: 0 26 04 064 31 0C NEIGHBOR=31 SEQ=2 RANK=2
- OSW: 0 18 24 000 06 28 CURRENT SITE=6
- OSW: 0 24 01 083 12 31 TX FREQ LCN=1 OFFSET LO=2668
- OSW: 0 24 01 133 16 1A TX FREQ LCN=1 BAND=1 TIER=3 OFFSET HI=0 OFFSET=2
668
668
- OSW: 0 25 01 110 04 7E RX FREQ LCN=1 OFFSET LO=3524
- OSW: 0 25 01 128 01 50 RX FREQ LCN=1 BAND=0 TIER=0 OFFSET HI=1 OFFSET=7
620
620
- OSW: 0 24 07 077 24 38 TX FREQ LCN=7 OFFSET LO=2488
- OSW: 0 24 07 133 16 5D TX FREQ LCN=7 BAND=1 TIER=3 OFFSET HI=0 OFFSET=2
488
488
- OSW: 0 25 07 110 16 05 RX FREQ LCN=7 OFFSET LO=3536
632
632
240
240
8620
8620
1228
1228
7680
7680
668
668
620
620
488
488
632
632
240
240
8620
8620
1228
1228
7680
7680
668
668
620
620
- Avg sampling rate: 22037 Hz Modulation: 17% LTR Modulation: 18%
DSheirer
Fulton, NY
Steve,
Looks like you found an undocumented site and it appears that there are two other undocumented sites nearby. Here's what I pulled from the log you posted:
Site 6: Tonawanda (Erie)
LCN01 153.3350 (TX) / 159.5250 (RX) Home Status Channel
LCN07 153.1100 (TX) / 159.5400 (RX)
LCN09 151.5500 (TX) / 173.2750 (RX)
LCN11 151.5350 (TX) / 159.6000 (RX)
Neighbor Sites:
62 - undocumented
28 - undocumented
31 - Attica
The Rochester site also reports site 28 as a neighbor. Site 62 must be a new site.
Saint
Site
Steve,
Neighbor Sites:
62 - undocumented
28 - undocumented
31 - Attica
Thanks for the info and all your help, If I set this system up in my 396t as a LTR trunked system will it trunk ok and will I beable to pick up the talk groups and audio also ???
Steve
Saint
LOG from 153.605 mhz
This is the log from 153.605 MHz only a couple of minutes
- OSW: 0 25 05 121 00 0C RX FREQ LCN=5 OFFSET LO=3872
- OSW: 1 01 01 255 05 13 BUSY FREE=5 LCN=1
- OSW: 0 28 00 017 00 1F ACTIVE LCNS LO: 1 5
- OSW: 0 28 04 000 00 2E ACTIVE LCNS HI: -none-
- OSW: 0 26 00 033 01 42 NEIGHBOR=33 SEQ=0 RANK=1
- OSW: 0 26 02 065 28 6D NEIGHBOR=60 SEQ=1 RANK=2
- OSW: 0 26 04 097 30 7F NEIGHBOR=62 SEQ=2 RANK=3
- OSW: 0 24 01 090 04 5F TX FREQ LCN=1 OFFSET LO=2884
884
884
- OSW: 0 25 01 115 24 0E RX FREQ LCN=1 OFFSET LO=3704
800
- OSW: 0 24 05 071 24 55 TX FREQ LCN=5 OFFSET LO=2296
- OSW: 0 24 05 133 16 60 TX FREQ LCN=5 BAND=1 TIER=3 OFFSET HI=0 OFFSET=2
296
296
- OSW: 0 25 05 128 01 2A RX FREQ LCN=5 BAND=0 TIER=0 OFFSET HI=1 OFFSET=7
968
968
- OSW: 0 18 24 000 28 07 CURRENT SITE=28
884
884
800
800
296
296
968
968
884
884
800
800
296
296
968
884
884
800
800
296
296
968
884
884
800
296
296
/ Avg sampling rate: 21994 Hz Modulation: OVERDRIVEN LTR Modulation: 32%
Saint
Submit info
DSHEIRER, OR E99god, if you guys could submit the information to the board I would appreciated it, I'M not sure what info to submit and don't want to mess things up.
Steve
GTR8000
NY/NJ Database Guy
BEE00
Steve
Already taken care of. Thanks for the info, Steve. :)
GTR8000
NY/NJ Database Guy
BEE00
Yes, any of these sites you find, please post the logs so Denny can translate them into English for the database. Thanks!
Saint
156.5550 mhz
156.5500 mhz was flashing talkgroups like the other frequencies but it was a very weak signal I tried to log the info but the signal is too weak, now I notice I'm not picking up the signal at all so conditions are just not right for this frequency. I am going to listen in from time to time on this frequency to see if a strong signal comes in and will post a log when I can on this frequency.
Steve
DSheirer
Fulton, NY
Steve, congrats ... you found site 28:
Site 28: Lockport (Niagara)
LCN 01: 153.6050 (TX) 159.7500 (RX) WPRH367
LCN 05: 152.8700 (TX) 159.9600 (RX) WPWD625
Neighbors:
33 - Rochester
60 - Avon
62 - Unidentified Site
Denny
k2hz
Rochester, NY
156.5550 is in the VHF Marine Band and can't be a legitimate frequency. I suspect it is a spurious response in your receiver.
156.550 (CH 11) is used for Seaway Traffic Control (Seaway Newcastle) in your area and I am sure there would be a major problem if Mobiletech was operating only 5kHz away since Seaway Newcastle is wideband CSQ.
Saint
Fake
156.550 (CH 11) is used for Seaway Traffic Control (Seaway Newcastle) in your area and I am sure there would be a major problem if Mobiletech was operating only kHz away since Seaway Newcastle is wideband CSQ.
Thanks for the info I agree with you and the signal has disappeared now.
Steve
