Mocks Corner Police
Schoolcop
Gales Ferry
Hi, Could someone please tell me what frequency or trunked system that the Mocks Corner police are on. I checked the database and only found info for the fire dept. Thanks for the help.
WGONE968
Goose Creek,SC
Moncks Corner P.D. dispatches off of the County Municipal Channel. It is 155.5950 with a PL of 186.2.
Jamestown, Bonneau, and St. Stephen P.D. use with channel as well.
The Moncks Corner Units will have the designation of "Kilo" in front of their numbers. (Kilo 1 Kilo 2 and so forth).
Central (dispatch) will use Bonneau, and Jamestown prior to those units and I believe St. Stephen will be Sierra.
Hope this helps
Wally
Schoolcop
Gales Ferry
Thanks so much Wally I was going down there for the holidays and thought I would listen in while there. Again thanks. Gary
