Mode for ISR Radio?
KB5FAS
Central Arkansas
What mode should I use when programming the ISR Radios into the scanner? Is there much activity on bases with the radios? Also, I had heard the Civil Air Patrol was using them now -- anyone heard them on?
Thanks in advance!
Joe KB5FAS
SkipSanders
Silent Key
ISR Radios are really FRS radios with the frequencies changed. Other than the retuning, they're just FRS units. So, yes, like FRS, they're narrow FM.
CORN
Nashville, TN
Narrow FM. I noticed the local CAP was using Icom 4008Ms at an event and found their freq right away using a Yaesu VX-3.
prcguy
What was the freq if i might ask? The usual 148.15? or 148.125? and in what mode? Just curious as the CAP is in transition here in TN as well.
prcguy
396.8750 ISR Channel 01
397.1250 ISR Channel 02
397.1750 ISR Channel 03
397.3750 ISR Channel 04
397.4250 ISR Channel 05
397.4750 ISR Channel 06
397.5500 ISR Channel 07
397.9500 ISR Channel 08
398.0500 ISR Channel 09
399.4250 ISR Channel 10
399.4750 ISR Channel 11
399.7250 ISR Channel 12
399.9250 ISR Channel 13
399.9750 ISR Channel 14
prcguy
b52hbuff
In my experience, the only usage I found was Civil Air Patrol at an airshow.
I was hoping to find some usage at the MCAS Miramar airshow, but it seems like rental radios rule the day.
KF4ZTO
The CAP does use their 148.150 and 148.125 simplex freqs, or repeater freqs, depending on if your Wing has started the migration to the new P25 repeater pairs.
As far as I know, 148.150 and 148.125 will still be in their radios.
And yes, ISR Radio is Narrow FM, ICOM IC-4008's retuned for 397 to 400 MHz.
They do have the 38 CTCSS "subchannels" still available as well. Hopefully we can expect to see more usage of these radios not only stateside but also for overseas military operations. The idea of giving every person in a unit a short range (500mW) radio is a great idea, and frees up FRS frequencies, especially in parts of the world where the frequencies for FRS are used by other services.
