ModeS Logger 4.1
GA!
#1
Hey Everyone,
I am trying to setup my live ADS-B feed for Live Military Mode's website and once I setup and run the ModeS Logger 4.1 program it tells me live update failed. I looked at both website settings under my information and the program settings they match but I am not sure why it keeps telling me live update failed? Only program that is running the same 30003 setting is Planeplotter but once I turn off Planeplotter it still gives me the same issue live update failed. Under where it says Hardware SBS-1 or Radarbox I put SBS (Using a Dongle). Is this correct? Yes, I emailed the administrator of Live Military Mode website to see what he says to fix the issue. Here is the website I am trying to live feed on.
- Jamie
https://www.live-military-mode-s.eu/
CYUL
Montreal, Canada
#2
Hey Everyone,
- Jamie
What IP are you using for the DB server?
GA!
#3
From what it shows on the Live Military Mode website I should use IP Database 85.214.149.157 is what I am using. It doesn't show any other information about what to use as far as updating to any other website or etc. I haven't heard from the gentleman who runs the website.
CYUL
Montreal, Canada
#4
Their responsiveness is terrible, been feeding into the site for a little while, but the IP they show is different from what I am using - I probably did not update it.
My IP: 85.25.235.202
Going to update to the one mentioned.
CYUL
Montreal, Canada
#7
I tested the IP you mentioned and it failed. Reset to this one: 85.25.235.202
I also confirmed on the site that my logs are populating.
GA!
#8
Switching to 85.25.235.202 fixed the issue! I appreciate the help.
:D
