Modify HT1000 Speaker MIC
WX5812
Fort Worth
I have several PMMN4045B speaker mics that go to the ht1000. is there any way I can cut the end off and attach a Kenwood 2 prong connector to it so it will work with other radios?
kayn1n32008
ØÆSØ
Sector 001
It’s not that simple. You most likely can’t just add the two plugs. The speaker mic likely has a bunch of electronic components inside, and would not work with your Kenwood. You would likely need to gut the mic, and ‘roll your own’ with the specific parts required to make your Kenwood radio happy.
Years ago I gutted a speakermic from a GP300 and built my own board with what my Kenwood needed for components, and only reused the speaker membrane switch on a circuit board and mic element, and added my own capacitor and resister and plugs for a Kenwood TH-79AD
Danny37
New York City
If you happen to get a 2 prong kenwood speaker mic, there's aftermarket 2 prong to muiltipin adapters for the xts/Jedi series radios.
KE5YCA
Danny, I believe Moto two pin commercial mics are spaced differently than Kenwood two pin commercial mics.
Kayn1n320078 has a fair point.
Especially when you consider that you can buy a complete aftermarket mic for the Kenwoods ... at less than the price of the radio cable required (Kenwood # E30-2102-28)
just to convert the Motos to plug in....and then figure out what you may need to alter circuitwise.
kayn1n32008
ØÆSØ
Sector 001
Problem is that it is spaced for Motorola 2 pin, which is significantly closer than Kenwood spacing. Also the pin outs are not anywhere close to the same. The 2.5mm plug on Kenwood has the speaker, where as it’s the 3.5mm plug on the Motorola.
Danny37
New York City
Yea I just realized that, my bad. Neat little adapter though.
