dmg1969
I was going to post this in the Uniden section, but think it is more of a general question. My BC125AT is the first scanner I have ever owned which allows you to change things like tones and modulation. That being said, I have two questions.
The first one is the difference between setting the tones to OFF or NONE on a given frequency. I think I figured that out. If set to OFF, it will break squelch whether or not it detects a tone. When set to NONE, it will only break squelch if it detects NO tone. Correct? I already know that setting a tone tells the radio to break squelch only if it detects the tone you have programmed.
Now, the next question is about modulation. I am not into amateur radio, so I do not have the electronics/radio knowledge that someone with that background would have. That being said, my question is whether it is best to have the channels in my BC125AT to AUTO for the modulation. If not, how do you determine what the modulation should be based on the frequency.
