Monitor 700 mHz P25
arlo
Can I use a Motorola radio with P25 option to monitor a single 700 mHz channel that is trunked P25?
IAmSixNine
Dallas, TX
P25 does not do trunking on a single channel.
Its conventional digital which does use a Talk group but its not trunking.
The simple answer to your question is Yes.
arlo
It is a trunked system, 6 repeaters, but only one repeater is in use. H is capitalized because it is a man's name. Hertz.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Depends on which Motorola radio you have, along with its feature set, and is the transmission you are trying to monitor TDMA or FDMA.
Unfortunately there isn't enough information to be able to answer the question.
arlo
I do not have a Motorola yet. I know there are 6 repeaters at the site. Only one is used daily. Uniden audio is not very good. I just want good P25 audio and no trunk following.
IAmSixNine
Dallas, TX
Your initial post said frequency. A frequency can be used individually or in a trunking system.
So that changes things. If its Phase 2 then you can not monitor them individually.
Uniden audio is good as i have a SDS100 and its great.
I also have Unication G4 which is another recommendation. Based on the info you have and have not provided us, id suggest SDS100 or a Unication G4.
jim202
New Orleans region
It would help if you identified what system your talking about and where your located. This way you should be able to obtain some details of what your looking to accomplish.
