Monitoring the U.S. Air Force Civil Air Patrol Auxiliary
N4CYA
GA!
I hear a lot of traffic on Tuesday from the 148.150 repeater here where I live in Tampa, Florida.
ecps92
Taxachusetts
Still on 110.9 / $455 ??
Yes 148.1500 and 148.1250 are the Two Repeaters, but knowing/confirming the PL and NAC help in determining which Repeater ID
thanks
N4CYA
GA!
thanks
Doesn't show the pl tone or nac when I hear them on my 996XT.
Sent from my iPhone 5 using Tapatalk 2
freqhopping
Lo Co VA/ FM19
Hearing some weak radio checks in northern VA on 148.125 analog. Now ending, but there will be another radio check at 1600z.
The Virginia Defense Force also happens to be doing radio checks this morning on the VA STARS system.
1412z- Now doing radio checks on 148.15 PL167.9 doing radio checks without replies. Same station is doing the call- Jefferson399. Heard a Free State (MD) unit check in. Now some Jefferson units checking in. Another check will begin in 2 hours.
1428z- ALE on 4.585. Some other tone is constant though.
1450z- Heard a Gaithersburg, MD unit calling on 148.15 PL167.9. Now faintly hearing someone on 148.15 PL146.2.
1454z-Gaithersburg Base on 148.125 PL141.3 now. Then getting a digital sounding signal that won't break squelch on my digital entry with NAC search for the same frequency. Opened squelch all the way and saw NAC585 briefly.
1530z- Culpeper,VA = Minuteman Base
ecps92
Taxachusetts
148.1500 167.9 - should be R-14 Mt Weather (VA)
148.1500 146.2 - should be R-26 Marbury (MD)
148.1500 141.3 - should be R-20 Easton (MD)
$585 would be from R-20
freqhopping
Lo Co VA/ FM19
That location for R20 doesn't seem right. That's 80 miles away. That's doable for me in the summer with ducting, but definitely not in the winter.
I think the R21 Ellicott City repeater is more likely.
An aircraft from Carroll Co MD is now airborne and on Air 1 analog.
Constant Watch net checks now beginning on R14.
Here's a good resource. http://mdcap.org/userfiles/file/MDWG_Repeater_Map_(Rev-004_10-23-2010).pdf
ecps92
Taxachusetts
Haven't seen any info listing Ellicott as a Repeater site
However, 100% Intel had R-20 as Easton, with R-01 thru R-64 , it would be ODD to put the same Freq/Tone within 200 Miles (Altho - they could have moved the Repeater since the info was obtained)
Anyone closer verify ?
Great Map
FYI - R-21 would be 148.1250 141.3 not 148.1500
http://wiki.radioreference.com/index.php/Simplified_Channel_List
N4CYA
GA!
Fixing to program my scanner with Civil Air Patrol frequencies to see what I can hear.
Anybody have any HF hits? Im getting ALE on 4585 & 9047USB but no voice traffic yet. Does CAP even operate HF voice traffic nets?
freqhopping
Lo Co VA/ FM19
I've only heard ALE. A little while ago on VHF I heard someone say they would being trying HF Ch26. Haven't heard anything on it.
Thanks man...Ive been scanning both HF and VHF and so far other than some ALE bursts I have nothing. Oh well.
N4CYA
GA!
Hey Guys & Ladies,
What day and time do they come on to check in?
