I'm trying to monitor VSP from Loudoun County using my new SDS100, but not having any luck so far.
At this point, I've added VSP to my FL as follows: USA > Virginia > Loudoun > Statewide > VA STARS > Virginia State Police, then 'Append to Favorites List'.
With all of the repeater locations, most of which are out of range, I thought it would be easiest to just enable location control for this system. When I start scanning, it appears to be scanning Dumfries, Fairfax, Independent Hill, and Mount Weather, which seems correct based on my actual location. RSSI is around 99-104 range when on Fairfax, none of the others seem to indicate a signal. Unfortunately, I'm not getting any audio.
I'm using the stock Uniden antenna, SQL set to 2.
Appreciate any tips anyone might have to help resolve my issue.
