Monroe County, FLA 10-codes, signal codes
Bote
Ft. Lauderdale, FL, U.S.A.
Monroe County codes
Monroe County just sent a sheriff to assist FHP investigate an alarm at a church in Marathon. Dispatcher had to repeat the call and stated it is a "Code 4", so I'm putting that down as "backup unit".
Code 5 = OK, 10-4, everything's good.
dcleistner
Key West Florida
Hmm strange, I will have to keep checking CAD. I got a look at a list of codes and I am 100 percent certain it said accidental. I will verify with my friend.
Bote
No, I don't mean that I've seen it on the Key West c.a.d., in fact I haven't looked at that in quite some time because it seems to show a limited subset of codes. I think what that web page shows is the clearance code, not the way it was dispatched. There is a wide range of codes that end up just being coded as disturbances when I know for a fact that they were dispatched as something else.
Other agencies use the acronym "MDOP" to mean malicious destruction of property, that's what I meant. I didn't think accidental destruction was so common that it required its own code.
dcleistner
Key West Florida
I think they would use Signal 33 Criminal Mischief/vandalism for any intentional property damage ie criminal mischief to a vehicle, criminal mischief to a house. I will verify.
