Montgomery County TXWARN
JonL008
Huntsville, TX
I have the Pro-197 and am located in Conroe. I am wondering where the tower is for Montgomery County Law enforcement. I can hear Conroe fine on the Edacs system however here in Conroe I can not hear the county at all on the p25 site. I was just wondering where the tower is located and if there was anything I could do to be able to hear them.
KevinC
Moderator
Super Moderator
Somewhere other than home :(
Two things...
1. I'm assuming your radio is programmed properly?
2. Site 51, which covers Montgomery County, is a simulcast site so it has 6 "sites" located around the county that all transmit on the exact same frequencies in unison.
JonL008
Huntsville, TX
I do have the Montgomery County simulcast programmed in. It picks up the CC however it is only about 50-60% on a good day, and even then If I hear anything at all its very limited and lots of static. Its picking up CC853.837500
KevinC
Moderator
Super Moderator
Ok, are you using the stock antenna or something external?
KevinC
Moderator
Super Moderator
I currently only have the stock antenna. Any suggestions for a decent indoor one?
I'll let someone else chime in with suggestions, every time I do people shoot them down. :D
With that being said, a different antenna would definitely make a difference. Whether it will make enough of a difference or not we don't know.
