cabfeegig
I wanted to get folk's opinions on a couple of questions: (for recieve only):
1 - What is the best wide band scanner antenna for atic or inside the house - OCD (66" or other length) o, multiple dipoles cut for specifc bands, or a J-Pole? Listening to 120->900 mhz.
2 - Can I attach multiple home grown antennas via 300 ohm (like an OCD and then a dipole cut for MILAIR) together to a balun and then to RG6, or will they muck each other up, or should they be separate runs then brought together via a reversed signal spliter?
3 - Where doe the 66" length come for the OCD sold by Grove and the home made one? I know the OCD is a 1/2 Wave length driven approx .33 percent off center. Is the frequency used to caclulate the base of the target frequence? So for Milair, it would be a total of 18.72" (assumeing 300mhz) driven at 6.23" from one end?
I used to be into scanners 20 years ago and have gotten the bug again. I have a BCD 396T with the RS 800 mhz that I used maily for trunking in the Tampabay area. I used an old PRO-26 for everything else.
thanks!
thanks!
