More Site frequencies on ws1080 than ws 1065
buckbull
#1
why does ez scan software have 12 site frequencies for trunked system and the ws 1065 only have 4 . It was downloaded through Radio Reference . Im guessing im missing some transmissions on the 1065 ? Any Thoughts ??
troymail
Silent Key
#2
I suspect your 1065 programming loaded only the 4 control channel frequencies but in EZ Scan you loaded (the default?) all site frequencies.
EZ Scan has an option to import/load only the control channel frequencies - and, IF the information posted is accurate, the control channel frequencies are all you really need.
However, if the information is wrong and/or changes (without notice), installing a subset of site frequencies could result in you hearing nothing from that site (that would be all or nothing - all talkgroups).
buckbull
#3
so im guessing im better off putting all 12 channels in both and leaving them in there.
buckbull
#5
Will it pick up transmissions quicker if i just put in the 4 channels as opposed to the 12 ?
