Morehead PD Dispatch
RonnieUSA
Rowan County,KY (Morehead)
Morehead PD has went NXDN, I'm not sure what the are hiding from, I guess they have to join there big brother MSU PD.
Here is a sample of what dispatch sounds like now.
talexhill
Morehead, Kentucky
I don't believe they're hiding from anything at all. Maybe they're working on communication improvements to better the safety of first responders.
It's not like specs for a two-way radio system is designed for scanner junkie listeners. It's designed for the people who actually use it, the first responders.
BigEd1314
London, KY
I would have thought they would go Mototrbo since Morehead as always been a political peeing match and very interop friendly between departments :)
