Morgan County
randytn
Southern Tennessee
#1
I live in southern TN 50 miles north of Decatur, I am receiving the Morgan County SD on 155.07. My question is are they using the 800MHz EDACS system yet?
North Alabama
#2
Yes, they are using it. But I don't think you'll pick it up 50 miles away. I'm only about 10 miles from Decatur and the signal is weak. The frequencies for the main Decatur site are:
856.2125
857.2125
858.2125
859.2125
860.2125
859.7625
860.7625
866.8125
867.0625
867.3125
#3
radiopro,
Are those listed in the proper LCN order? I'd like to input these into my scanner and see if I pick up from Huntsville
PP
North Alabama
#4
They should be. I have them programmed in my scanner in that order and it works fine. MorganAL also posted the frequencies for all three towers in my thread titled "Unidentified Trunking System".
morganAL said:
Here are the correct freqs for the Morgan Co system:
Decatur Main (Flint)(Located at the 911 Center next to Regional Hospital)
1. 856.2125
2. 857.2125
3. 858.2125
4. 859.2125
5. 860.2125
6. 859.7625
7. 860.7625
8. 866.8125
9. 867.0625
10. 867.3125
Decatur North (Located at Decatur City Hall)
1. 856.4875
2. 856.9875
3. 857.4875
4. 857.9875
Morgan East (Brindlee Mtn)
1. 855.7375
2. 859.9875
3. 860.9625
City Hall is off the air right now. Still waiting on the tower at City Hall to be replaced.
North Alabama
#6
delta_p said:
Thanks,
I picked it up but way too weak signal to listen.
PP
Yeah. Pretty much the same goes for me on the Huntsville Public Safety system as well. 800 Mhz doesn't travel too far. You may pick it up better if you had an amp or a specifically tuned 800 Mhz antenna though, both of which I don't have.
Somerville, AL
#7
Only a few units have it in their cars and they only use it for occasional BS. Most of their traffic is on 155.070 or Southern Linc.
#8
I do have an 800 Mhz yagi in the attic but I got it mounted aimed at Monte Sano Mountain to get HPS. Maybe I'll try turning it one day. I am able to pick up the Decatur PD on 460.325 and 460.450 very well on scantenna.
PP
