Morris County MIRS
tomn2tsr
#1
I just purchased a PRO-2096 and I THINK I have it programmed properly for the MIRS system, but, I am not hearing any audio. I'm new to trying to monitor digital trunked systems, but, I think I understand things - I'm just not sure that I understand things.
How often should I hear transmissions during the day? I've been listening for like 15 minutes and haven't heard a one.
But, sometimes, I see the scanner will stop scanning, show some information on the display (33104 or 33808 see common), but there is no audio coming out of the speaker.
I can hear other transmissions on non-MIRS frequencies (like county fire band 46.42, etc), but, no audio on the MIRS channels.
I am in Kinnelon, so, maybe that's the problem? I have the antenna in the attic and I can receive pretty well, I think.
Tom
tomn2tsr
#2
I should also specify that if I stop on the control channel by hitting MAN, I hear the appropriate data sound and the display shows 8911which corresponds to what I see in the database, so, I am also thinking that it is NOT a signal strength issue.
tomn2tsr
#4
Yes, I did.
Which brings up another question.
Since there are two listings in the RR database for the Base, Spacing and Offset, and I think I need to enter both, I think those two items have to be entered into two banks?
As such, do I need to enter all of the control channels in both banks also?
Pequannock, NJ
#6
You need to set up both sets of base, offset, step in a single bank. Also only enter the freqs from zone 2 (north).
I'm not familiar with the 2096 so cannot help you any further.
