Mot Type I/Type IIi Talkgroup Oddity...
Forts
Ontario, Canada
I've come across an odd situation... My work uses radios on a Mot system local to me, and thru some playing around I determined the talkgroup to be 29xxx (the xxx's are just because I can't recall the tg off the top of my head). Using that talkgroup to listen in with my scanner seems to work just fine, but I noticed other talkgroups weren't adding up. So, long story short what I thought was a Type II system is actually Type IIi, with mainly Type I talkgroups being used. Now heres where it gets weird. I had the chance to dump the codeplug from one of my work radios, so I did. According to the CPS, the Size Code is 'A' and the Fleet we are on is 350. So, I adjusted the Fleetmap in my 246T and Pro96 and key up my radio expecting it to show 350-1. It didn't. It shows 380-1, on both my radios. Anyone have any idea why? I played around with different size codes and I couldn't get 350-1 to show up at all.
fineshot1
NJ USA (Republic of NJ)
Most likely there are different display formats used between your motorola radios(you did not mention which motorola model radios) and your 246T & 96 scanners. I know from doing some of my own programming that the portables & mobiles I have programmed all have the talkgroups entered in Hex and I think the Uniden & RS is done in Decimal. I am not familiar with Type I talkgroup numbering(we use only II) so cant help you figure out the correct TG numbers. Hope you find your answer.......fineshot1
Forts
Ontario, Canada
I was kind of wondering something along those lines too. The radio I pulled the info from is an MTX850. I've also read 2 different GTX's on this system, and their info properly matches what appears on the scanner. I guess I'll hafta play a little more and see what I can turn up!
DaveH
Ottawa, Ont.
Fortz, :)
I think 350 means you are using Block 3, Fleet 50. Looks like the 50 is hex (50 hex =
80 dec.). The scanner is displaying a decimal Fleet number. Therefore 3-80-xx makes
sense.
Dave
