Motola xtl power plug
KD2ITM
So here is my issue,
I have a Motorola xtl 2500 that i picked up in my travels but the power plug that is soldered to the PCB is in rough shape. Would anyone happen to know what or where this part could be sourced from? Attached is a picture of the plug after it was "fixed" the side that the wires are coming out of once had the standard 2 pin power and groud plug.
Any help you be great. Thank you
rescue161
KE4FHH
Hubert, NC
Per the detailed service manual, here is the part:
Item Number. 0905902V07 - CONNECTOR DC - $12.17
The plug reference on the board is J0950.
Now go give whoever soldered the wires directly to the plug a serious beat-down.
NMO's installed, while-u-wait.
Wow, that got totally "redneck engineer'd".
I suspect I have a few of those connectors that I've salvaged laying in a box somewhere. If I find one this weekend, I'll let you know.
You can sometimes find them on e-Bay. You could also pick up a "parts" radio and salvage it. They are common amongst the Motorola radios.
KD2ITM
Rescue161, is this detailed service manual floating around here somewhere or is it something you got from a Motorola shop?
Mmckenna, if you find one that would be great if not I'll keep searching eBay and what not. Just trying to avoid going to the local Motorola shop.
Thank you for your help!
KD2ITM
I honestly keep a digital copy of it myself. I don't like breaking it out though since its in 5 parts. I tend to just use the BSM if I can.
BSM meaning basic service manual?
I took a look at the main power board and it looks like there is a SMD resistor by the antenna jack that looks to be blowen (no contenuity throught it) any ideas as to if it is in fact a resistor or somthin else. It is the only component by the antenna port. Thoughts?
KD2ITM
Which side of the board? Is it labeled?
When you pull the cover off its under the board so i would guess bottom? There is not tag or number on it. There os a few other components that look the same and come up with 2.2 ohms. Obviously this is checking the still soldered to the board so who knows. It has little red dots on it.
rescue161
KE4FHH
Hubert, NC
R5713 - 3.3K - Is the larger resistor farther away from the antenna connector.
R5710 - 75K - Is the one closest to the antenna connector. It's also very small.
Both resistors have one side connected to the the center conductor of the antenna and the other side of each is connected to ground.
Are these two what you are seeing?
Disclaimer:
This is for the UHF Range 1. Depending on the range of your radio, these values and/or components may be different.
KD2ITM
Disclaimer:
I only see 1. This is a VHF only as far as i know.
rescue161
KE4FHH
Hubert, NC
This is from the service manual and shows it as an inductor on the VHF board.
L3737 2462587N69 CHIP IND 1200 NH 5%
Somehow I missed that this was a VHF and assumed that it was 800 MHz. Sorry about my misunderstanding. Don't know how I missed it. You should be able to locate that part now, but there is probably nothing wrong with it.
KD2ITM
Thank you!
