Motorla SyntorX9000 in a 2002 Ford Tarusus
sgtmatt
Platteville Wi
Hi All, Just wondering how'd you go about installing a Motorola Syntor X9000 in a 2002 Ford Taurus. Not real sure so I thought I'd turn to the radio community for help. Also wodering if anyone can reccomend a good antenna?
Matt Alexander
jparks29
John McClane
Nakatomi Plaza
what band? I'd go with a 1/4 wave for simplicity.....if it's LB, then you'll be 'stuck' with a baseload 1/4 wave......unless you want a ball mount...heh..
run red wire to battery, fused....
black wire to ground....
run control head cable to mounting location for control head....
wire in org/grn leads for constant/switched ignition (on control head)
mount speaker......
good to go..
