Motorola Antenna RAB4003ARB
Nassau County, NY
#1
Hello,
Can anyone tell me if this radio antenna has a coil spring attached to the base? Looking to get this, trim it to 29.5" and then use it for the 46MHz portion of the band.
MOTO RAB4003ARB 36-42MHz
Strasburg, Va
#2
36 to 42 antenna
my experience with this type of antenna (ASPA-552 Antenna Specialists we gave used ones of them away free) is that far off frequency it does not transmit well. For receive it probably is acceptable with some loss. You would be better off without the coil like we use to do for receiving on low band receivers for press and scanner listeners we removed the coil cover and took off the coils and ran a wire cut from from unused coils from bottom center to top where u can resolder it to the lug for the base of the antenna rod. Check your nearby 2 way shop junk box
Nassau County, NY
#3
If you take the 36-42MHz antenna and trim it to 29.5", it actually works perfect in the 46MHz range
