Motorola ASTRO spectra MON button.
I have enabled the monitor button via CPS. Pressing it once gets you on or off but, holding it down allows you to turn sq to zero which in turn gives you hash/white noise in analog mode. This does not happen on a astro personally ?
Sent from my SCH-i605 on Verizon 4G LTE.
jim202
New Orleans region
Programmed buttons on Motorola radios follow the type of application your using. You were not forth coming with a very good description of just how your trying to use the MON button. Is this in an analog personality or are you trying to say this is in a digital personality? I know you said Astro, but many people confuse what it means and how it is used.
I'm using the button the same way you would a portable. Yes on a astro personality "p25".
mikewazowski
Staff member
Forums Manager
Oot and Aboot
What did you expect to hear? The radio is expecting some sort of digital signal and it's not finding it so you hear nothing.
I'm trying to get it to unmute so I can hear the scramble when someone is transmitting in secure mode.
