Motorola BC130/BPR40 ceramic filter replacement
matty909
Fontana, California
when I programmed my bc130 it narrow banded my radio and my green led was stuck on. after reading a post here I am under the impression that my ceramic filter has gone bad and was a common problem when making a switch from wide to narrow band in these radios. after some searching I found this Motorola ceramic filter part
91012021001 - Motorola CERAMIC FILTER ALPHA L - ShopWiscomm
the filters in my radio have M55GW & M55FW
this replacement part from what it looks is M55GW or M55GWE ?
would this be the correct replacement part? I believe with my filters 1 is wide and 1 is narrow so is M55GW a narrow band filter?
I don't know much on this so I am asking here in hopes someone can point me in the direction of the part I need, thank you
matty909
Fontana, California
I hard reset the radio, changed the squelch to tight and yes it will get the green light to turn off but if you open the squelch it sounds distorted and even being next to the the radio and keying up it will not receive. I spoke with a tech at the shop and explained what info I had come up with he said "you are absolutely correct, and unfortunately it's a 15¢ part but it will cost a flat fee of $75 to get repaired"
