Motorola CM200D Pinout/Jumper
wb6sub
Antelope Valley, CA
I am installing a CM200D MOTOTRBO radio and I see that it has a new pin setup than previous Motorola radios. The pinout on the radio shows 1=Speaker -, 11=Flat/Filtered RX audio, and 16=+ Speaker audio. Is there a jumper on this radio as in previous radios?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Unlike the older Radius radios, audio jumpers have not been needed for quite a while. None of the Pro or Comm series mobiles require them.
Most installs don't involve the accessory connector much except for Ignition Sense these days, at least on these two series.
Project25_MASTR
Millennial Graying OBT Guy
Texas
GM300, Maxtrac and GTX are the only 16 pin radios that need to be jumped for audio. SM120 (successor to the GM300), M1225, CM/CDM/PM radios need only have the internal speaker disconnected if using an external speaker.
