Motorola CP 200 not Receiving tones,,,
ITFD
Hey all a new member here... I have a CP 200 radio that suddenly stopped receiving on all channels. I tried transmitting with it at the Fire Hall and it will transmit on the primary (#!) channel. The thing is my son had carried it upstairs for me and since then it won t pick anyting up. No he did not drop it.
The reason I ask is I had a Motorola Vista before and it had a series of two buttons to press at the same time to reset it.
Does the CP 200 have a similar sequence to press to reset or does it need to be serviced.
Thanx
Steve
I.T.F.D. #39
fineshot1
NJ USA (Republic of NJ)
Check to make sure the priority function was not accidently enabled
or
Perhaps one of the two programmable buttons was pressed and another
function enabled
ITFD
or
function enabled
How can I check this, I was just issued this radio 2 weeks ago and I am still a bit of a virgin with its operation.
trooper890
N/A
cp200
they are funny beasts.
Are you getting a two beep self test pass when you power up?
If you are getting a "bonk" when you turn the radio on, the radio needs to be serviced.
Do you use a remote speaker/microphone? The radios audio accessory ports are, well not exactly durable. Try flexing the jack back and forth and see if you get audio. Could also be the internal speaker is bad. I would highly recommend using the audio accessory retainers that are available to protect the jack if a RSM is used full time.
fineshot1
Sorry but I do not have the user guide(which I assumed you have) so start pushing buttons and experimenting with the radio or perhaps someone else here can advise you.
N1GTL
CT
... The thing is my son had carried it upstairs for me and since then it won t pick anyting up. No he did not drop it.
Did he carry it by the antenna?? The lug can break off the board.
Also, the two side buttons are CPS programmable. Depending on what the client orders, the buttons do different things but resetting the radio is NOT one of them.
