Motorola CPS 16.0 Build 823
Tommis
Morris IL.
I am looking to legally download a copy of Motorola CPS 16.0 Build 823 software. I have a few older Mototurbo radios and I would like to program them. Am I able to download that from the Motorola website? When I try using CPS 2 I get a codeplug error, tells me I need to use version CPS 1. I'm assuming CPS 16 would be what I'm looking for. Thank you
n3obl
Ø
PA
latest cps 16 is build 828. If you have access on myview it should still be available on MOL.
Firebuff880
Boynton Beach, FL
Not necessary ! Check the radio through the menu to determine what release of Firmware is in it and then you can determine what CPS you need. But CPS 2.0 should / will work with anything that CPS 16.0 Build 828 will.
com501
If the firmware in the radio is more than two years pre 16.0 Build 828, Trbo 2 will not be able to read it. Get Build 828, update the F/W in the radio to 2.09 and go from there.
Tommis
Morris IL.
Thank You Will a firmware upgrade delete the programming in the radio? Also is there any negatives to upgrading firmware?
N1XDS
ÆS Ø
Good question to ask. Sometimes when performing a firmware update to a radio of any kind may freeze the radio or at times brick the radio but I never seen it happen when I am updating my radios. Never does hurt to update the firmware from a radio or radios all depends on the user and what they need fix in a firmware update for their radio they are using at home, on the job or etc.
Tommis
Morris IL.
Thank You
Thank You
