Motorola CPS Dealer Login Bypass??
D
Drake1731
Guest
Hello, is their a Motorola Dealer Login Bypass for the CPS? I read that If you can login then you can change your radio to whatever frequency that's in its frequency range, is that true? I'm looking to program it to Green Dot. Its an RDV2020
WA0CBW
Shawnee Kansas (Kansas City)
You can contact Motorola and request different frequencies other than the per-programmed ones. You need to tell them what frequencies to be removed and what frequencies to be added and they will send you a new frequency file. However they will not program them with frequencies for which the radio is not FCC certified. That radio is NOT certified for a green dot frequency (MURS) and that radio has also been discontinued so not sure if they would create a new frequency file for a discontinued radio.
BB
D
Drake1731
Guest
BB
I appreciate your response, thanks!
