XTL/XTS5000 Motorola digital to Icom Digital
westcoaster
Will the Motorola XTS 5000 (II) communicate with an Icom IC F5061D (IDAS) on a digital channel?
Not looking for anything complex, just simple good old fashioned clear channel simplex communication.
If it does, any tips on programming it?
Second question: Will the XTS 5000 do simple voice inversion scrambling?
I am able to get the Icom to receive (to my ear) a digital signal from the Icom.
I'm thinking most of my issues are in the conventional personality tab....
westcoaster
Thanks for the reply,
Saves me fooling with this any further....
I had an inkling that was the case....
ElroyJetson
The F5061 is one of Icom's first generation IDAS products and as a result it suffers from defective firmware code
that means it will exhibit a roughly 0.5 to 1 percent rate of missing calls in digital mode.
I don't know if they ever fixed that issue with later firmware releases but for that reason I advise to avoid first generation IDAS products if thyey are to be used in IDAS digital mode.
Apparently, Kenwood engineers figured out the problem with those Icom radios. They found a single bit error in the firmware that handles the IDAS codec. Kenwood radios are not and have never been affected.
