Motorola Evx-s24
Hello! I recently bought 2 Motorola evx-s24 radios and have noticed the following: 1) There are only 4 channels on my radio? and channel 1 and 2 do not work. 2) Only one Roger tone is played when usually there are 2. 3) When I press mode all it does is make a beep and doesn't let me do anything.
Please respond if u can help! Thanks
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
Did you program them to the frequencies that you are licensed for?
sfd745
Reverend Higgy
Southern Maine
You need to get the proper software for the radio, first and foremost. Then, you can add your licensed frequencies into the channel table. Then you select the channels you want into the zone table. These radios are really capable for a small radio.
Alarmguy
Former Alarm Guy, turned Radio guy
Deep in the heart of Jersey
You are going to need a USB Mini-B cable and the CE157 software from Motorola and make sure you are licensed with the FCC for the frequencies you intend to use. If you can find a local dealer you would be better off.
