Motorola ex600xls programming
Racefan
I trying to program my ex600xls radio I have HVN9025Ab, R06.12.08, it reads
the radio with no problem, but when you try to write it, it
says the CPS operation on this device failed
Any ideas as to why??
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Are you using 64bit version of Windows?
Racefan
I've tried it on Windows XP, Vestia, and Windows7 which is a 64, it does the same on all 3
Racefan
Well that's not it either tried it on a windows xp with 32bit os and it does the same
thing it will reads the radio, but will not write to it
Ant9270
The Green Weenie
What was the last version software the radio was Written with?
kmh603
Try going to properties and then select run as an administrator and also select compatibility mode and try Windows 7. That’s what i use and it works for me
